Автор Тема: Грешка при аваст  (Прочетена 1454 пъти)
Неактивен CNews
  • Начинаещ
  • Публикации: 57
Грешка при аваст
« -: Май 26, 2008, 05:32:10 pm »
Това е при компа на еедин приятел.
iAVS Обновяване:
26.05.2008 17:29:57 general: Started: 26.05.2008, 17:29:57
26.05.2008 17:29:57 general: Running setup_av_pro-491 (1169)
26.05.2008 17:29:57 system: Operating system: WindowsXP ver 5.1, build 2600, sp 2.0 [Service Pack 2]
26.05.2008 17:29:57 system: Memory: 77% load. Phys:56784/253420K free, Page:246672/620912K free, Virt:2069264/2097024K free
26.05.2008 17:29:57 system: Computer WinName: PC
26.05.2008 17:29:57 system: Windows Net User: SYSTEM
26.05.2008 17:29:57 general: Cmdline: /downloadpkgs /noreboot /updatevps /silent /progress
26.05.2008 17:29:57 general: DldSrc set to inet
26.05.2008 17:29:57 general: Operation set to INST_OP_UPDATE_GET_PACKAGES
26.05.2008 17:29:57 general: Old version: 491 (1169)
26.05.2008 17:29:57 system: Using temp: C:\WINDOWS\TEMP\_av_proI.tm~a00416 (33803M free)
26.05.2008 17:29:57 general: SGW32P::CheckIfInstalled set m_bAlreadyInstalled to 1
26.05.2008 17:29:57 internet: SYNCER: Agent=Syncer/4.80 (av_pro-1169;p)
26.05.2008 17:29:57 system: Computer DnsName: pc
26.05.2008 17:29:57 system: Computer Ip Addr: 10.44.68.134
26.05.2008 17:29:57 system: Installed in: C:\Program Files\Alwil Software\Avast4 (33803M free)
26.05.2008 17:29:57 internet: SYNCER: Type: use IE settings
26.05.2008 17:29:57 internet: SYNCER: Auth: another authentication, use WinInet
26.05.2008 17:29:57 package: Part prg_av_pro-491 is installed
26.05.2008 17:29:57 package: Part vps-8042400 is installed
26.05.2008 17:29:57 package: Part news-4b is installed
26.05.2008 17:29:57 package: Part setup_av_pro-491 is installed
26.05.2008 17:29:57 package: Part jrog-37 is installed
26.05.2008 17:29:58 file: SetExistingFilesBitmap: 1054->154->154
26.05.2008 17:29:58 general: GUID: fe0d74c2-e990-4358-90a4-1d6405617560
26.05.2008 17:29:58 general: Server definition(s) loaded for 'main': 182 (maintenance:0)
26.05.2008 17:29:58 general: SelectCurrent: selected server 'Download503 AVAST Server' from 'main'
26.05.2008 17:29:58 package: GetPackages - set proxy for inet
26.05.2008 17:29:58 internet: SYNCER: Type: use IE settings
26.05.2008 17:29:58 internet: SYNCER: Auth: another authentication, use WinInet
26.05.2008 17:29:58 general: Entered SetupProcessPro::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:29:58 general: Entered SetupProcessWin32Avast::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:29:58 general: Entered SetupProcessWin32::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:29:58 general: Entered SetupProcess::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:29:58 general: progress thread start
26.05.2008 17:29:58 internet: SYNCER: Agent=Syncer/4.80 (av_pro-1169;f)
26.05.2008 17:30:00 internet: Used server: http://download503.avast.com/iavs4x
26.05.2008 17:30:00 file: GetFileWithRetry: servers.def.vpu downloaded .
26.05.2008 17:30:00 file: GetNewerStampedFile:DSA_FileVerify(C:\WINDOWS\TEMP\_av_proI.tm~a00416\onefile), error: 0x2000000B
26.05.2008 17:30:00 package: Download servers.def, servers.def.vpu failed with error 0x20000011.
26.05.2008 17:30:01 internet: Used server: http://download503.avast.com/iavs4x
26.05.2008 17:30:01 file: GetFileWithRetry: servers.def downloaded .
26.05.2008 17:30:01 file: GetNewerStampedFile:DSA_FileVerify(C:\WINDOWS\TEMP\_av_proI.tm~a00416\onefile), error: 0x2000000B
26.05.2008 17:30:01 package: Tried to download servers.def but failed with error 0x20000011.
26.05.2008 17:30:01 general: Err:The package is broken.
Информация за текущото обновяване:
Последна грешка: Пакетът е повреден.
Общо време: 28 s
Обновяване на програматра:
26.05.2008 17:31:38 general: Started: 26.05.2008, 17:31:38
26.05.2008 17:31:38 general: Running setup_av_pro-491 (1169)
26.05.2008 17:31:38 system: Operating system: WindowsXP ver 5.1, build 2600, sp 2.0 [Service Pack 2]
26.05.2008 17:31:38 system: Memory: 77% load. Phys:56024/253420K free, Page:241144/620912K free, Virt:2069264/2097024K free
26.05.2008 17:31:38 system: Computer WinName: PC
26.05.2008 17:31:38 system: Windows Net User: SYSTEM
26.05.2008 17:31:38 general: Cmdline: /downloadpkgs /noreboot /silent /progress
26.05.2008 17:31:38 general: DldSrc set to inet
26.05.2008 17:31:38 general: Operation set to INST_OP_UPDATE_GET_PACKAGES
26.05.2008 17:31:38 general: Old version: 491 (1169)
26.05.2008 17:31:38 system: Using temp: C:\WINDOWS\TEMP\_av_proI.tm~a01104 (33803M free)
26.05.2008 17:31:38 general: SGW32P::CheckIfInstalled set m_bAlreadyInstalled to 1
26.05.2008 17:31:38 internet: SYNCER: Agent=Syncer/4.80 (av_pro-1169;p)
26.05.2008 17:31:38 system: Computer DnsName: pc
26.05.2008 17:31:38 system: Computer Ip Addr: 10.44.68.134
26.05.2008 17:31:38 system: Installed in: C:\Program Files\Alwil Software\Avast4 (33803M free)
26.05.2008 17:31:38 internet: SYNCER: Type: use IE settings
26.05.2008 17:31:38 internet: SYNCER: Auth: another authentication, use WinInet
26.05.2008 17:31:38 package: Part prg_av_pro-491 is installed
26.05.2008 17:31:38 package: Part vps-8042400 is installed
26.05.2008 17:31:38 package: Part news-4b is installed
26.05.2008 17:31:38 package: Part setup_av_pro-491 is installed
26.05.2008 17:31:38 package: Part jrog-37 is installed
26.05.2008 17:31:39 file: SetExistingFilesBitmap: 1054->154->154
26.05.2008 17:31:39 general: GUID: fe0d74c2-e990-4358-90a4-1d6405617560
26.05.2008 17:31:39 general: Server definition(s) loaded for 'main': 182 (maintenance:0)
26.05.2008 17:31:39 general: SelectCurrent: selected server 'Download914 AVAST Server' from 'main'
26.05.2008 17:31:39 package: GetPackages - set proxy for inet
26.05.2008 17:31:39 internet: SYNCER: Type: use IE settings
26.05.2008 17:31:39 internet: SYNCER: Auth: another authentication, use WinInet
26.05.2008 17:31:39 general: Entered SetupProcessPro::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:31:39 general: Entered SetupProcessWin32Avast::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:31:39 general: Entered SetupProcessWin32::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:31:39 general: Entered SetupProcess::Do( INST_OP_UPDATE_GET_PACKAGES )
26.05.2008 17:31:39 general: progress thread start
26.05.2008 17:31:39 internet: SYNCER: Agent=Syncer/4.80 (av_pro-1169;f)
26.05.2008 17:31:40 internet: Used server: http://download914.avast.com/iavs4x
26.05.2008 17:31:40 file: GetFileWithRetry: servers.def.vpu downloaded .
26.05.2008 17:31:40 file: GetNewerStampedFile:DSA_FileVerify(C:\WINDOWS\TEMP\_av_proI.tm~a01104\onefile), error: 0x2000000B
26.05.2008 17:31:41 package: Download servers.def, servers.def.vpu failed with error 0x20000011.
26.05.2008 17:31:41 internet: Used server: http://download914.avast.com/iavs4x
26.05.2008 17:31:42 internet: Used server: http://download914.avast.com/iavs4x
26.05.2008 17:31:42 file: GetFileWithRetry: servers.def downloaded .
26.05.2008 17:31:42 file: GetNewerStampedFile:DSA_FileVerify(C:\WINDOWS\TEMP\_av_proI.tm~a01104\onefile), error: 0x2000000B
26.05.2008 17:31:42 package: Tried to download servers.def but failed with error 0x20000011.
26.05.2008 17:31:42 general: Err:The package is broken.
Общо време: 15 s
Неактивен GlowNDark
  • avast! bg support
  • Потребител
  • Публикации: 183
    • avast! antivirus bulgaria
Re: Грешка при аваст
« Отговор #1 -: Май 26, 2008, 07:45:24 pm »
Проблемът може да е пречинен от кофти интернет или от прекъсване на ъпдеита преди.
Може да пробвате да си изчистите TEMP директирията да рестартирате компютъра и да видите какво ще стане...
Неактивен XMAS
  • avast! translator
  • Администратор
  • avast! freak
  • Публикации: 1017
    • avast! на Български
« Отговор #2 -: Май 28, 2008, 08:11:56 pm »
Също така може да пробвате да изтеглите цялата вирусна база данни от интелнет и така ръчно да обновите програмата. http://files.avast.com/iavs4pro/vpsupd.exe и след това да видите дали отново ще имате същия проблем.
Между другото коя версия на програмата се ползва ?
Неактивен rusi2606
  • Новак
  • Публикации: 2
« Отговор #3 -: Август 29, 2008, 06:14:41 pm »
При проверка на компютъра, която не се осъществи излезе съобщение AVAST!: AAVM подсистемата откри RPC грешка. Някой знае ли за какво става дума?
Неактивен terminator
  • Потребител
  • Публикации: 102
    • Форума на Буковлък
« Отговор #4 -: Септември 11, 2008, 09:25:38 pm »
Може да се е сринал нета по време на обновяване, на мен така ми се случи веднъж. След като пусна компютъра аваст се включва при старта , заедно с LAN-a и VPN-а. Добре но някой път виртуалната се дисконектва няколко секунди след като в вързана, а аваст проверява и тегли при старта и намиране на сървъра, и така му прекъснах обновяването.
-Как се нарича компютър с инсталирана Nod32?
-Компютър без антивирусна защита.
